Pro 5S battery drain
  • 5 Replies
  • 903 Views
Jeff__h
Have 2 5S cams.  One actively records during the day.
One is idle and not active daily unless I activate it.
first battery last 2+ months before charging.
Second battery drains to 10% within 2 weeks yet is inactive.
both units are new and in use for about 5 months.
Cam with the drain problem has always been a problem.
I’m thinking the battery is defective.
Both units are on the same floor and close proximity to the WiFi point.
Anyone having the same battery problem and if so, did a new battery resolve the issue?
Best answers
  • Jeff__h
    I pulled the battery to rest the device.  Still monitoring the unit but it appears to have resolved the problem..I hope.
    Thanks.
5 REPLIES 5
Try swapping the batteries, and see if the problem moves with the battery (or not).
Jeff__h
Good idea. Will try. Should have thought of this but at my age the brain becomes unreliable😂
Jeff__h
Thanks.
FYI, pulling the battery on a Pro 5s reboots the camera, but does not reset it.
But of course it did resolve the issue for you.
Jeff__h
Yes…I know that.  Just resets the battery connection
