Have 2 5S cams. One actively records during the day.
One is idle and not active daily unless I activate it.
first battery last 2+ months before charging.
Second battery drains to 10% within 2 weeks yet is inactive.
both units are new and in use for about 5 months.
Cam with the drain problem has always been a problem.
I’m thinking the battery is defective.
Both units are on the same floor and close proximity to the WiFi point.
Anyone having the same battery problem and if so, did a new battery resolve the issue?
Try swapping the batteries, and see if the problem moves with the battery (or not).
Good idea. Will try. Should have thought of this but at my age the brain becomes unreliable😂
I pulled the battery to rest the device. Still monitoring the unit but it appears to have resolved the problem..I hope.
Thanks.
FYI, pulling the battery on a Pro 5s reboots the camera, but does not reset it.
But of course it did resolve the issue for you.
Yes…I know that. Just resets the battery connection
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
