Pro 5S 2K camera registration fails with a notice on the phone of "No cameras were found". The camera chimes on QR, flashes BLUE until the end of the sequence and then flashes RED, and stops flashing all together.
I am using a Cisco wireless network and have defined a 2.4Ghz only network SSID and have connected my iPhone and the camera to it.
I can see the camera on the network and I can "ping" it from my computer, so I know it has successfully DHCP'd an address. BTW: this also happens with an Essential Wireless Doorbell that I also purchased at the same time.
I am replacing an older Gen 1 arlo camera system that has worked on this same network for 5+ years without a problem.
Please make a suggestion if you have any. Thank you!
Try using PC (my.arlo.com), and see if that works. Connect the PC with ethernet if you can.
That of course uses a base that connects via ethernet, so not at all the same.
There is far too much friction when onboarding newer Arlo cameras - IMO they really need to take a closer look at what they can do to fix that.
Agree! Thx for the suggestion. I'll give it a go
Any updates, I am having the same problem?
Not yet. Trying to work with their support folks. Very painful!
Are you using a Cisco wireless controller?
No, netgear but getting same symptoms. I have a doorbell connected no issues but when I try to add the 5s I can get to the barcode and scan with beep then led flashes fast amber and eventually goes out. I have verified I am on my 2.4Ghz SSID and am in the process of checking router settings but everything else is working. I read another post that said certain characters in the network name or pwd can cause connection failures and I tried removing those but same results.
My SSID is ARLONET, so that's not my problem
rr77, ssb1
Try checking your security type within your router. Change to WPA2, if it's not selected already.
Also try checking to see if there are any additional firewall settings enabled.
I had several different options for WPA2 and had to select a different option. Very strange that there were no issues setting up the doorbell, I would have thought all of the arlo cameras would use the same protocols. I ended up setting up a guest network with the correct WPA2 option just to set up the 5s cameras, after they were set up I switched them to my regular 5G network and then removed the guest network.
One difference between doorbell and camera is that the doorbell can only do 2.4Ghz. The Pro 5S can do 2.4 or 5Ghz. Maybe a clue? If so, I've not figured it out.
LMK if you see anything suspicious
FWIW, the Pro 5s is dual band, so can connect to 5 ghz. Have you tried just onboarding the Pro-5s to your normal SSID?
I am wondering about the 801.b/802g selection on the bottom screen. You could try later protocols (802.n, 802.ax), and see if that makes any difference.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
