Pro 5S 2K Motion trigger
Question... I have a 4 camera set up, all wireless and all connected to continuous power source. The motion trigger seems to be very slow and the motion sensor erratic. For instance, for the most part the cameras don't seem to pick up motion and trigger a recording until the subject is right in front and on top of the camera. I'd like to see activity sooner. At other times it will send me an alert for something that is happening 75 to 100' away, which is supposed to be way outside the sensor range.
My back porch camera picks up movement that is 7 or 8 feet away, but won't trigger a recording from motion 15 feet away. All of this is well within the viewing range... Does the motion sensor not cover the entire range of the camera? If not don't you think they should... I certainly thought it world.
Billa32778,
There are several things to consider when it comes to motion detection. Camera position, signal strength, distance to the object being detected, etc. all play a part in how the camera will behave. For tips on what you can do to make sure your camera is positioned for best performance, take a look at this article: https://kb.arlo.com/1015583/How-do-I-optimize-motion-detection-for-my-Arlo-camera
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
