  • 2 Replies
  • 3988 Views
Popeyespond
I just switched to Verizon 5G wireless internet. I had the 2.4G from another carrier and it (the camera) worked great.   Do I just re-setup my camera ?   Or is there something special I have to do ? Do I need to buy a hub or something ? I can't find if the hub is wired into the router or is wireless ?     Any help would be appreciated. Thank you.........
Jeff / Central PA
https://www.youtube.com@jeffandhispond
The simplest thing to do is change the Verizon wifi settings to match your old wifi's network name and password.
Otherwise, you need to remove the Pro 5s from your account, and then onboard it again.
Popeyespond
Thank you so very much !!
