Pro 5 2K nothing shows up in Feed
Hi There
We brought the Pro 5 series (4 cameras, 4 Solar Panels and the Hub)
No subscription
One day in the App the Feed was showing notifications, snapshots etc.
Next day nothing, just the Arm Away activated etc. This has been going on since about May.
Version (4.16.1_28692)
Android
SmartHub: VMB4540r3 - We have a usb plugged in and this works fine
Every time I have come onto support there is a message saying
"Some customers in Australia and New Zealand regions may be experiencing problems with live streaming and motion recordings. We are working to resolve this issue" So is this still and issue??
I am from NZ and these cameras were not cheap. Well over $1,000 dollars, so tempted to take them back.
Several more queries.
1: If we disconnect and then reconnect all cameras and the smarthub will this fix the issue?
2: If we subscribe will this allow the feed to start feeding - Showing snapshots etc?
Please be gentle as I am new to security cameras.
Thanks in advance.
Mel
Hello Mel
It's likely that the free trial has expired, but you'd also need to check that you have rules in place to record.
Assuming that you have rules in place to record, from now on, to access your recordings if you have them enabled to record to local storage, you need to go to Devices > SmartHub > SmartHub > Storage Settings. The reason why it's not as easy to access them is because Arlo wants you to buy a subscription.
The other answers are:
1. No
2. Yes, but it depends
Thank you very much.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
