Options to set max battery charge level in App for alwasys connected unit.
  • 1 Reply
  • 43 Views
dhung
I am requesting a feature that allows users to set a maximum battery charge threshold (e.g., 50% or 80%) for cameras that are permanently connected to an AC power source or solar panel.
The Problem:
Lithium-ion batteries experience accelerated wear and potential swelling when maintained at a 100% charge state for extended periods. Since the Arlo Pro 5S 2K requires a battery to be physically inserted to operate—even when on AC power—users cannot simply remove the battery to preserve its lifespan. Currently, the camera keeps the battery at 100% indefinitely, which will inevitably lead to premature battery failure.
Proposed Solution:
Add a toggle in the Device Settings called "Battery Health Mode" or "Stationary Power Mode."
  • When enabled, the camera would stop charging once the battery reaches a user-defined or pre-set limit (ideally 50-60% or 80%).
  • The camera would then run off AC power, only drawing from the battery if the AC source is disconnected.
Benefits:
  1. Longevity: Significantly extends the physical life of the battery.
  2. Safety: Reduces the risk of battery swelling/bloating.
  3. Sustainability: Reduces the frequency of battery replacements and electronic waste
DannyBearAgain
I recall an earlier discussion on this a few years ago.
Arlo cameras only charge the battery to 80% capacity to maximise operating life although the Arlo app's  battery status says 100%.
The stand alone Arlo battery charger unit will charge the battery to the full 100% capacity so it not recommended to leave them on charge when they are fully charged.
https://kb.arlo.com/1179176/What-do-the-Arlo-camera-battery-level-icons-and-notifications-mean
