After updating to the new app (that is a disaster btw) my cameras have stopped detecting. I’m running 2x#Pro4 and 1x#Pro5s.
i have no detection zones, adjusyed sensitivety to max, tried switching on of cameras manually, different modes, uninstalled the app, nothing makes my cameras detect. The positions are the same.
Also tried resetting one of the cameras (#pro4) but now the camera will not connect to the same wifi it was connected to. All wifi settings are the same as before.
Anyone hava a solution for me?
Did you use this procedure to reset, including removing the camera from your account?
https://kb.arlo.com/000062880/How-do-I-factory-reset-and-re-sync-my-Arlo-camera-Arlo-Secure-4-0
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
