Local Storage on Arlo VMB4540 Smart Hub Without Subscription?
  • 198 Views
EiLo
Hello everyone,
I was considering buying a used Pro SmartHub VMB4540, and the seller mentioned that he was selling it because he could not use it for local video storage without an Arlo subscription.
Before I make any decisions, I would like to confirm: Is it possible to record and store video locally on this hub using an SD card or external hard drive, completely subscription-free? If anyone has firsthand experience with this, I would greatly appreciate details on any limitations or required configurations.
Thank you for your insights!
Yes.  It won't accept an SD card, but it has USB ports.  I recommend using a thumb drive, not an external drive.  128-512 gb is enough (the max is 2 TB).
There are limitations
  • recordings are only available in the app (not the web browser).  So you cannot see them on a PC
  • recordings are only available using the primary account (not "friend" accounts).
  • no thumbnails, so videos need to be downloaded to the phone before you see anything.
  • no ability to make manual recordings or snapshots
  • remote access requires router setting changes that many find difficult, and which will not work with some internet service providers.
Note there are other subscription features - one that is often needed is activity zones.  Some cameras do support activity zones w/o a subscription, but only when the camera is AC powered.
Also, you do need to use cameras that are compatible with the smarthub (some only connect to your home wifi).
EiLo
Thanks for the quick and detailed reply! Really appreciate it.
I just wanted to ask; both the seller I spoke with and a forum user recently mentioned that Arlo now charges $9.99 to store video locally. This seems like a new issue. Is that correct, or is the local storage functionality still as you described?
That is not correct.  I think they were confusing local storage with cloud storage.
You do need a subscription to access Arlo support (other than for warranty issues)
