How to get the Pro 5s FIELD TRIAL FIRMWARE # 1.040.28.13_152_2450fc8 right now ??
@roundball we already moved you to the FT in a previous post are you seeing the behavior you recently seen?
Hello BrookeN...
No, my pair of WIFI connected 5s with the Field Trial Firmware are still working OK.
My question was more of a general one:
A) I have a couple other 5s that I haven't WIFI tested with the Field Trial Firmware yet;
B) Because other individuals have problems / need to get / try Field Trial Firmware;
Can we good arlo customers download / try the Field Trial Firmware for ourselves ?
I can have you cameras moved to the field trial if you would like.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
