I have had to both reset and reconnect directly my base station to a Sky pod. The base station appears on the app but asks for a password when I try to connect a camera. Any suggestions
Best answers
Are you sure you are telling the system to connect the camera to your base?
It sounds like you are either trying to connect to the base wifi from your phone (which cannot be done) or you are using the wrong workflow path, and are inadvertently connecting the camera to your home wifi.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
