  • 9 Replies
  • 4854 Views
Mitchell1976
I have 5 Arlo Pro 5 Camera's and noted there is a discrepancy between the firmware numbers:
4x VMC4060AerH5 running 1.040.28.17_195_ac8359b
1x VMC4060AerH53 running 1.050.32.4_65_b51262d
Although at first I was not aware of the different hardware numbers, after looking which firmware the camera's were running on, my eye fell on this as well.
Does somebody know what is going on and why I am not able to update the firmware of these 4 Pro 5's to the -apparently- latest 1.050? I have reset these camera's multiple times, without any success.
ShayneS
@Mitchell1976
After checking again, it appears this firmware version for your devices are in a slow rollout release for all regions. Your other devices will slowly update over night as the firmware is pushed out.
Best answers
9 REPLIES 9
Arlo slow-rolls their firmware updates, and it is not uncommon for updates to reach different cameras in your account at different times.  Plus, the "update firmware" control won't show you the most recent firmware until Arlo is ready to push it to that specific camera. So there is nothing you can do to force the pace.
I'm tagging the mods - @BrookeN , @JamesC , @ShayneS - as they might be able to schedule a push for the four cameras that are behind.
Mitchell1976
Thank you for your reply; do you know if there is any difference between the
VMC4060AerH5 and the VMC4060AerH53? And I was also wondering if there is an updated page with information on the current firmware versions, as the one on this community seems to be outdated?
The ARXHxx suffixes are small hardware revisions.  Arlo doesn't publish what they are changing, but I think they are usually component substitutions that are either done for cost or availability reasons.
ShayneS
@Mitchell1976
This is the link to the firmware versions: https://community.arlo.com/t5/Firmware-Release-Notes/Arlo-Firmware-Release-Table/m-p/1920885#M791
As Mentioned, firmware releases are generally in slow roll-out phases and may be limited to some regions temporarily.  The link provided above will have the most recent released/dates.
Mitchell1976
Dear @ShayneS ,
as the firmware versions page mentions 1.040.28.17_195_ac8359b for the VMC 4060 and, as stated above, I have one running on 1.050.32.4_65_b51262d, I don't understand what is going on. Could you explain?
Best regards,
Michiel
ShayneS
@Mitchell1976
1.050 is the latest version. The link provided just needs to be updated, to reflect the release.
Are all your Pro 5 cameras on this version now?
Mitchell1976
@ShayneS
No, only 1 out of 5
ShayneS
@Mitchell1976
Mitchell1976
@ShayneS
Thank you very much for sorting it out. I will report back as soon as the devices have updated.
