Constant Notifications when in Low Power Mode
Whenever my Arlo Pro 5S 2K camera goes into Low Power mode I get notifications for all motion, even though the system is configured to detect only people.
When not in Low Power mode everything works just fine. I only receive notifications when the camera detects a person. However, as soon as it switches to Low Power mode I get constant notifications for any motion (for example, trees blowing in the wind).
Is this a software defect or a known issue?
First, Smart Notifications does not change detection - the servers use the recording to determine what caused the detection.
As for Low Power Mode, I haven't used it so can't comment on exactly how it works but it may well be correct operation. I believe you should be getting snapshots, not videos, when in LPM - is that true? If so, the servers can't determine the cause of the detection base on a single frame.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
