Connection problem
  • 1 Reply
  • 904 Views
augustalexandra
Hi,
I recently purchased the Arlo Pro 5 2K, but I haven't been able to connect it to my network successfully. I have tried connecting to the 2.4 GHz network and have turned off the VPN, but it still doesn’t work. Could you check which steps I may have missed and help identify the problem?
You may want to try resetting the camera:
https://kb.arlo.com/000062880/How-do-I-factory-reset-and-re-sync-my-Arlo-camera-Arlo-Secure-4-0
Make sure your WiFi has no special characters, including spaces, for the SSID and password. Also ensure the encryption is set to use WPA2 (AES).
