How do I change location and timezone on my account - I now live in a country that doesn’t support the pro5 2k and need to change my location so I have the correct timezone
Select the profile icon in the upper left of the app, and then select the location. There is a setting to change the time zone there.
Thanks for your suggestion however it doesn’t allow me to change either country or timezone - those options are greyed out - I can change address but not country.
I wonder if it might be because I have relocated to a country where Arlo is not supported?
Maybe. FWIW, my app does let me change the timezone. But that wasn't always the case - it used to lock the time zone to the address (if an address was entered for the location). and I am currently running a test version.
You could try setting up a different location without an address, and see if that lets you set the timezone. But I'm not sure if you can transfer the cameras to that location without losing the subscription.
I'm tagging the mods ( @JamesC , @BrookeN , @ShayneS ), to see if they have any suggestions.
Thanks 🙏
Support should have reached out to you to explain this expected behavior. If you have any further questions, please let me know.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
