I can't change the settings on my Pro 5S 2K, in particular the field of view size and the activity zone, but I suspect it's any setting. Also, when I have the mode on Standby or Arm Away, my Pro5S 2K still videos, whereas my two Pro 3 cameras switch to Standby or Arm Away. In other words, it seems my Pro5S 2K is just hooked up and running at all times with, I'm assuming, default settings that can't be changed. My Pro 3's are paired to the Arlo Hub Base Station, whereas, my Pro5S 2K is connected to my WiFi. Could that be the difference?
Did you install the camera to this account? Or are you accessing the camera from a shared "friend" account?
Did you check the rules in the modes?
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
