Can I use the Arlo pro 5 without having 2.4ghz wifi at home? I have taken the camara to a friends house who has got 2.4ghz wifi to set it up and it worked fine I thought that when I went home I could also connect it to my 5ghz wifi that I have at my house but it isn't letting me connect just keeps telling me no cameras can be found
The Pro 5s is dual-band, so it doesn't need 2.4 ghz.
That said, you almost certainly do have 2.4 ghz, as almost all 5 ghz routers are also dual band. What router model/manufacturer do you have?
There are other problems that can interfere with onboarding. If you are getting the chime from the camera when you install it, then also check your router's attached device list, and see if the camera is listed there.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
