Eero Mesh Fix
  • 0 Replies
  • 3472 Views
  • 1 In Conversation
MAGA24
Hi all ! I am writing this in hopes you do not have to go through what I and many other frustrated users have gone through. Arlo support as well as Eero support could not figure out why the cameras were not connecting.  Eero has an “Advanced Security Feature” called “WPA3” the standard is WPA2 which is what Arlo cameras are set to. By disabling this feature and making sure you are on the 2.4 ghz network by disabling the 5ghz network, you should have no issues connecting. From Eero Home Screen in the app you have to go to security or Eero Labs then security. From there toggle off the WPA3 and there ya go ! The mesh network is better than the base station extender
0 REPLIES 0
