Camera
Hi,
some reason the picture in camera 1 is upside down on my screen so how do I change it so it’s right side up and how do I get the audio to work? The cameras came with NO owners Manuel and I can’t find the info on line and of course Arlo will not give out a customer service number to call
Go into the video settings, and look for a "Rotate Image 180 degrees" control.
- Can you explain what isn't working?
- audio in recordings played on the phone?
- audio in recordings played on the PC
- audio in livestreams on the phone
- audio in livestreams on a PC
- person at the camera isn't hearing you when you use two way talk
- something else?
@Chris02639 wrote:
The cameras came with NO owners Manual
Hi,
where is the video settings? I am in the app all that’s on the bottom is dashboard, feed, emergency, device, routines' I don’t see settings,
and for the audio if I am watching the camera when away from my house I can’t get the audio to talk or hear the person at the door talk it’s just silent
Select devices, and then touch the camera image. You'll see a settings wheel in the upper right - press that, and then touch "Video Settings".
Start by downloading a recording, and then see if you hear anything when you play it.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
