Arlo Pro5s battery life
I am running a 3 years old Essential wire-free video doorbell and a newer Pro5S. Prior to the Pro5S I had an older version of a cam which worked fine for years. All of a sudden the battery of the older one was empty after one week, so I thought maybe a battery problem and I bought another battery…same problem.
So I thought maybe the cam is too old and I bought the Pro5S.
Unfortunately the same problem. The old doorbell battery works for months, the Pro5S is empty after one week. I tried all the possible settings, no improvement, changed to distance to the router, no change. And the doorbell has much more alarms than the 5s in the garden.
I use both of them directly connected via wifi to the router. I must say that when not using wifi, we switch the wifi off on the router. I thought maybe this is the reason that the 5S tries to contact the router constantly even when I use the standby mode in the app? But what makes me wonder is: why does the doorbell not have this problem and why did this work for a long time the way we use it with the older cam and then started causing the problem from one day to another and still persists even with a brand new cam?
Thank you very much!
Pat
Is the doorbell connected to your existing wiring which would continue to charge the battery?
No, the doorbellcam is not wired to the existing doorbell, battery and wifi only
Best not to do that with the security cameras.
Yes we have other reasons to do that, we do not need the cams all the time because we have other security features. But this still does not solve my problem because with the old cam this worked fine for a long time and with the doorbell too.
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to the Profile icon > Support Center > Select device > contact
5s
Accessing Local Storage
Accessing Local Storage.
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
detection
drained battery
Firmware Update
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
wind
wireless
Zones
