Arlo Pro 5s geofence not working
I am unable to setup geofence automations in the Arlo app. If I go to settings -> privacy center -> account -> available geofence devices then I can see all my logged in devices.
But if I go to routines -> automations -> add an automation ->add arrive/leave -> select arrive or leave then the screen shows "No Devices" and so the automation cannot be created. Screenshots of the two attached, although it isn't clear they've worked....
I have tried for weeks to contact support about this but the webchat will never connect me to a person, it just goes through the useless automated replies and then says support is only open 9am-6pm even when I'm using it in the middle of the day. When I log in the VIP support that should be included in my plan never shows up - it always invites me to upgrade my subscription to include this instead. So I'm desperately hoping someone here will be able to help instead. The whole account, website and support system seems to be unbelievably hopeless!
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
