Arlo Pro 5S non-stop audio recordings
I have a couple Pro5S cameras installed at my father's home in France. One of the cameras has continually recorded Audio every few minutes. I've disabled the microphone and audio on the camera but it continues to record and has been draining the battery even with the Arlo solar panel powering it. I've reset the camera several times and that has worked for a little while but the camera eventually starts recording again. Though I've disabled Audio notifications, I'm worried it will eventually run out of power in the next few weeks.
Have you tried adjusting the motion sensitivity? Sometimes this also can cause an issue with audio recording. I've noticed with my cameras when i turn audio detection off i still need to adjust the motion some.
https://kb.arlo.com/000062777/About-Arlo-Routines-Modes-Rules-and-Automations
You need to turn off audio detection in the camera rule(s). Turning off the mic prevents audio from being captured, but it doesn't affect audio triggering. Information on how to modify the camera rules is here:
Also, check the smart notification settings, and make sure that Smoke/CO Alarm alerts are off. There have been issues with audio alerts in the past when these are enabled. (The Pro 5s doesn't have a smoke/CO sensor, it is listening for the chirp of a nearby smoke detector).
5s
Accessing Local Storage
Accessing Local Storage.
Arlo Cameras
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
drained battery
low power mode
Magenta screen
metal barns
Night vision
No recordings
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
wind
Zones
