Please - can I connect the external magnetic charging cable to an existing external power supply that is currently used for a permanently-powered floodlight or does it have to be connected to an internal power socket? Thank you.
Arlo Pro 5
What is "an externally-located power supply"? the Arlo power brick just needs to plug into the typical wall socket - does your power supply offer that? There's no way around that without somehow modifying the Arlo equipment.
Assuming you mean the indoor cable, which isn't weatherproofed, it would have to be a USB (5v) connection. The outdoor charger has a permanently connected cable so can't be (easily) used. Also, the outdoor charger supplies 9v which may or may not be an issue.
Thanks for your answer. No, I was planning to use an external cable with a permanent connection both to the camera and to the existing external power supply.
Without using the magnetic connector, you'd need to hack the camera and/or case to get power properly applied. And it still needs to be 5VDC, not something like house power that runs the floodlight.
I am so sorry but I think that we are talking cross purposes here. My intention is to use the proprietary Arlo external power supply, not a home-made one. I would use the magnetic connector to connect to the camera but am wondering how/if I can connect the mains power brick to an externally-located power supply. Thanks again for your help.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
