chicane
I've had ongoing headaches with my Pro 5S cameras not detecting events or taking snapshots instead.
Today I did a side by side test with a Pro 4 camera in the same location. Both devices are on 2.4GHz and connected to an outdoor Ubiquiti AP (great signal strength for both). I did try the device on 5GHz and found it to be similarly flaky so reverted to a hopefully more stable 2.4GHz connection. Unfortunately not.
Since I have done this side by side test, the Pro 4 is detecting every event (and recording a video).
The pro 5 recorded video once, completely missed one event and recorded a snapshot instead for the third event. With the video was choppy and audio partially missing at the start, while the Pro4 was smooth and had audio for the full clip.
Both devices are active under my subscription, set identical under the routine (to record video), and smart notifications set the same.
I've had this replaced with a new sealed unit by support for the second time with the same outcome.
Are these devices inherently faulty? anyone else experiencing similar?
Best answers
  • BrookeN
    The firmware has started rolling out. It should be completed within the next week. As soon as that is fully rolled out the behavior you are seeing will be resolved.
  • BrookeN
    I have this escalated to the engineering team. I will update the community as soon as possible.
976 REPLIES 976
roundball
Virtuoso
Virtuoso
@chicane
Thanks for sharing...never heard anything about that before.
If that was the case, may have been a timing thing for me because that's when all my 5s WIFI cams firmware got updated.
Bottom line, the past couple weeks of my 5s cam operation has been what I assumed it would be when I bought them months ago.
PS:  Reference firmware:
Are yours also running the new 'Field Trial Firmware' ?
( Field Trial Firmware # 1.050.33.6_71_393f539 )
chicane
@roundball it's a combination of both that would have improved the situation.
The old & new Field Trial Firmware would have fixed the snapshot instead of video issue, however the laggy performance was addressed by the cloud/server side changes.
I have two different firmwares on my two deployed Pro 5S cameras, one is the one you mentioned, the other is the older 1.040.28.17_195_ac8359b firmware. I will ask @BrookeN via direct message to get this on the latest (and greatest?) field trial firmware release.
roundball
Virtuoso
Virtuoso
@chicane   .....Thanks for the info.
Hope the new Field Trial Firmware helps you out.
@BrookeN  has been terrific helping us through this mess.
Next question will be:
When does it become "production".....AND.....available for end users to upgrade other 5s cams, like we normally do Firmware upgrades.
a102768
My Pro 5 is still on 1.040.28.17_195_ac8359b, so I can't comment on the field trial software.
The snapshots stopped within a few weeks of getting the camera but I suspect I am still missing alerts, particularly overnight. When I was using my old Essential Spotlight camera I used to get 4 or 5 alerts a night as my cat wandered down the drive to and from her other 'families' in the neighbourhood. I don't think her habits have changed but I rarely get alerts overnight now.
I noticed the other night when I was trying to get my Pro 5 working with Apple Homekit that the infrared camera wasn't operating as the image was pretty much black. Switching night vision off and back on again seemed to fix it then but I have noticed in the past that when I look at the live stream after dusk the image is very pixelated and dark so I wonder whether the camera isn't switching into night mode properly so doesn't 'see' anything.
I bought a hub (VM4540) a few months ago to see if it would help with the on-going Pro 5 issues but am struggling to see the point of them. I finally worked out why I couldn't see the images stored locally after discovering a post about allowing the Arlo App access to the local network on my iPhone but the hub seems to corrupt the USB dongle every few weeks and also both times when I have rebooted the hub. The last time it did it I couldn't even do a fast format on my laptop as it just errored when I tried, so had to do a long format.
I have connected my doorbell and Essential to the hub but when I try and view them in the app I just see a grey image with a spinning icon on both until the app connects to the hub, which can take 5-10 seconds if I haven't looked at it for a little while. When the trial on the Pro 5 expired I also moved it onto the hub but that was the same and there was a 5-10 second delay between getting an alert and the video thumbnail appearing on the alert. I have therefore moved the Pro 5 back onto wifi connect. There is still a delay but no where near as long.
I was also fed up to find that now that the free trial has finished on the Pro 5 the basic subscription no longer has the smart object detection and filtering (vehicle, animal, person) that I had on the single camera plan my Essential was on and the only way to get it back is to subscribe to the Plus plan which is significantly more expensive than the plan I was on with the Essential, NZ $19.99/month instead of < $5.
All in all, I wish I had just carried on using the Essential and not wasted my money on the Pro 5 and hub!
roundball
Virtuoso
Virtuoso
@a102768
You might ask Moderator @BrookeN if she'll have the latest Field Trial Firmware down loaded for you.
Also, just a suggestion in case it might have any influence...there have been a couple of upgrades to the User Interface App...might want to check and be sure yours is at:
Version 5.0.3 (8458)   /   Released Oct. 2, 2024
And FWIW.....on occasion, it seems like I've benefited by completely uninstalling the UI App from my phone, then going to the App Store and downloading a complete fresh copy of the app.
a102768
Thanks for the tip. My copy of the app is from July so I will definitely update and see if that makes a difference.
roundball
Virtuoso
Virtuoso
@BrookeN  and all.....10.14.24 UPDATE
It's now been 25 days.....and all four WIFI attached 5s cams still seem to be working as they should...overall a huge continued improvement !!
NOTE:
I HAVE begun to notice a new common problem among all the 5s cams so I assume it's something common at the host end, not a problem on all 5s cams at the same time.
NEW PROBLEM IS:
While any motions of tree limb movement shadows on the driveway...small birds...squirrels...etc, are being detected and notifications sounded immediately...the detected movement itself is being posted to the Feed much slower than normal.
Appearance in the Feed now runs 1 to 1.5 minutes after the notification.
Anyone else having slow downs with detections appearing in the Feed?
It's now been 12 days....
It's now been 7 days.....
Hope I don't jinx myself saying this...but FWIW, the past 3 days since the latest 5s Firmware...(Field Trial Firmware # 1.050.33.6_71_393f539)...has been installed / operating on all 4 of my WIFI attached 5s cams, everything seems to be working as it should.
Fast, clear, catching all motion, immediate notification, posting to Feed quickly, etc. Hope it lasts, will keep my fingers crossed.....
BW32205
Can you experiment with viewing the feed via a desktop/laptop browser, versus Smartphone app?
@BrookeN  - any way to get that version on hub-connected cameras yet?
roundball
Virtuoso
Virtuoso
@BW32205
Well, since the Feed is in the UI App...I 'assume' the Feed is only accessible via the App.
Could be wrong of course...
If your app shows "Feed" and "Dashboard", then my.arlo.com does too.
roundball
Virtuoso
Virtuoso
@StephenB
Agree...
I didn't get that he was referring to going to the arlo site to see the feed...thought he was asking about simply using a local browser to see the Feed quicker...my bad
BW32205
I was wondering if there's a noticeable delay between what you see online versus via the app. The app may be web-based, but there may be a lag.
BrookeN
@BW32205 can you please dm me the email address associated with your Arlo account.
roundball
Virtuoso
Virtuoso
This 5s forum seems to have become pretty quiet.
Is no one else having any more 5s related problems ?
GW1a
Hi all Can I please ask those who have previously posted on this Forum if they are still experiencing problems with their Arlo Pro 5s camera, or if all their issues with the camera have now been resolved? I am a new Pro 5s owner who is experiencing most of the issues in this thread and am considering whether I just return the camera and move to another brand, or stick with it on the assumption the problems can be resolved quickly?
roundball
Virtuoso
Virtuoso
@GW1aA lot of the problems do seem to have been cleaned up. I’m no authority…speaking only from my experiences, a couple of things:
1) Be sure you have the latest version of Field Trial Firmware installed.
( # 1.050.33.6_71_393f539 )
 Would have been coordinated for you by Moderator @BrookeN;
2) Download the latest October version of the Arlo App from the App Store;
roundball
Virtuoso
Virtuoso
@BrookeN and others:
My 4 active 5s cams have had what I’d been told was the latest “Field Trial Firmware” ( # 1.050.33.6_71_393f539 ) for the past few weeks, providing noticeable improvements..
I haven’t seen any ‘Community Postings’ about any new 5s Firmware, and was surprised to find that all my 5s Firmware has been replaced.
Current Firmware is now:  # 1.050.33.8_90_76db0d4
Is this a new 5s ‘Production’ Firmware ?
PS:
Is it available for ‘End User download’ to other 5s cams waiting to be used?
Will it allow 5s cams to work on ‘Base Stations’ or only WIFI Direct ?
roundball
Virtuoso
Virtuoso
@BrookeN  and all.....not hearing back from any source, I dragged out / installed another 5S on WIFI to trouble shoot the situation.
It still has old Firmware # 1.040.28.17_195_ac8359b on it.
And it says there is no new Firmware available for it.
For the life of me I cannot understand how arlo continues to operate like this.....especially in spite of at least having an online Community Forum like this where they could easily communicate status.
chicane
@roundball it baffles me as well.
Gaslighting customers pretending there are no issues.
@BrookeN we appreciate your assistance with getting us on field trial firmware.
However, the broader user base is stuck with an expensive faulty product with a company unwilling to acknowledge known problems formally.
Why is Arlo so inept and unwilling to be honest?
AlixO
Hi @BrookeN - I’d also like to please know if the firmware version 1.050.33.8_90_76db0d4 is the latest version and if Arlo considers this version has fixed all recent issues with delayed notifications, missing events etc? Both of my Pro5 cameras are now on this version, however I watched a bird walk right in front of one of my cameras a couple of days ago and the camera didn’t pick it up - the Essential camera I had in the same spot used to always pick up birds, and the Pro 5 only picks them up sometimes, including on the new firmware. My other Pro 5 camera recently picked up a fox overnight - it’s set to record for 31 seconds but for some reason only recorded for 6 seconds, even though the fox was moving around within the camera’s range.
These sorts of things have been ongoing problems, for nearly 6 months. I don’t want to be difficult, but I’m tired of the Pro 5 cameras’ sporadic and sub-par performance.
roundball
Virtuoso
Virtuoso
@BrookeN @AlixO @chicane  and all...
SUMMARY:
The latest “Field Trial Firmware” ( # 1.050.33.6_71_393f539 ) for the past few weeks provided the best 5s operational performance I'd experienced over the past many months of arlo aggravation.
Then as I've recently posted, to my surprise I began noticing Feed related issues:
Fast 'notifications'.....but terribly slow posting of the actual motion recordings to the Feed.
Now learning that without the professional courtesy of ANY communication what-so-ever after what I've been through for months and months...my good working Field Trial Firmware was all removed then replaced behind my back without my knowledge.
And the obvious assumption is that the surprise installation of Firmware # 1.050.33.8_90_76db0d4 is the culprit of the new set of Feed related issues !!!!!
Arlo need to fix the terribly slow posting of motion videos to the Feed ASAP.
MEANWHILE:
REINSTALL my good working “Field Trial Firmware” # 1.050.33.6_71_393f539.
Edinburgh_lad1
Mentor
Mentor
Wow!
@roundball @chicane @AlixO a rhetorical question: how long are you prepared to be testing for Arlo a product that should have been working from the start, considering that:
- you paid for it (big money) on the assumption that it's fit for purpose;
- making time and effort to test it;
- that it's been months, and;
- that you (probably) don't get any incentives like a year of free storage etc., let alone a thank-you from Arlo for all that.
I find this company's approach unacceptable.
Killhippie
Prodigy
Prodigy
I would NOT run beta firmware ever. The latest production firmware works just fine on both of my Pro 5's at £94 new from a well known online retailer during a sale so a bargain as well. Anyway don't try to fix with beta firmware what really may not broken and could be down to your network and signal strength, router or interference from other networks.
 Beta firmware will have bugs hence its a 'beta' and should be never run on devices you use daily let alone security cameras in my humble opinion. Also any back end changes and new software may be for production firmware not a random beta you just don't know, let alone with Arlo at the helm!
roundball
Virtuoso
Virtuoso
@Killhippie @chicane @BrookeN
No equipment / network issues on this end...examples:
I have three Pro4 cams on a Base Station.
All make immediate notifications & 10-15 second video posting to feed.
I have one additional 5s on the same WIFI as my other 5s cams.
It still has older Firmware on it yet it has the same fast posting to Feed.
My main four 5s cams were all working the best they ever had for a month with that latest Field Trial Firmware...then recently / suddenly began having very slow postings to Feed.
Discovered the excellent Field Trial Firmware had been replaced with some unknown Firmware.
a102768
I suspect the slow feed is a back end issue. My Pro 5 is still on 1.040.28.17_195_ac8359b and there was a period a month or so ago when the thumbnail was appearing almost instantly with alerts but it’s gone back to a 5 second or so delay again.
