Arlo Pro 5S - Dual Band WiFi Question
We are working to determine if the Pro 5S’ dual band WiFi will address issues that I have when mounting cameras to metal buildings. We live on a Hobby Farm with pole and walk-in sheds that we want to monitor - but mounting cameras near the metal on the barn causes disruption in the signal. Is there anything that we can do and will the Pro 5S address it?
Thanks!
-Bob
Arlo Cameras
metal barns
Wifi connection
It's the metal that's the issue. ANy chance you can position the cameras on a pole or other non-metallic object nearby and still get the view you need? I suppose adding a wooden extension from the barn that's long enough to help isolate the camera signal from the metal could be useful.
I figured as much and have moved my camera’s of the barn and sheds. Perhaps someday we’ll come up with a solution to address this.
Thanks!
5s
Accessing Local Storage
Accessing Local Storage.
Arlo Cameras
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
drained battery
low power mode
Magenta screen
metal barns
Night vision
No recordings
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
wind
Zones
