I have four Arlo Pro 5S 2K cameras. All of them seemed to set up properly. When I go to “live” streaming one of them does not show 2K in the upper left corner. Is there a setting I have wrong? Also, does this mean it is not using 2K when it records? I restarted all of them, and that didn’t help.
Try downloading one of the recordings to a PC and examine the resolution there.
With Windows, you can right-click and select properties. Then go to the "Details" tab, and look at frame height and frame width. 2K has width=2560 and height=1440
If "Auto Zoom & Tracking" is turned on, recordings and livestreaming will revert to 1080p.
Thanks for the helpful responses. The best solution was to do a hard reset of the device. It is working fine now.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
