My Expensive 5S captures car coming up a driveway but movement is always in short jerky motions, kind of start stop movement. But my inexpensive and old Arlo Q mounted a few feet away but behind a window, always shows the cars movement on one fluid action. Car moves exactly as you would see it. Is there an adjustment that I can make on my 5S?
thanks, Bill
Can try…thanks! Will close out this thread
Do you have Auto Zoom & Tracking enabled in the camera video settings? If not, this could be a signal strength/quality issue. What does the WiFi indicator show? Have you tried a different location for troubleshooting to see if that makes a difference?
Thanks, Auto Zoom and tracking is off. This camera sits outside about 3 feet from an indoor Arlo Q camera looking through a window. Both have the same view. Both are about 55’ to 60’ from Base station and two walls. Both signal bars are in the middle 🛜 yet the cars motion with the Q is perfectly smooth……Bill
I suppose the difference in resolution/data rate between cameras could be an issue. The distance to the Pro 5 could easily be causing the problem. If it's connected to WiFi, can you move a WiFi extender closer to teh camera, at least for testing?
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
