We are having a problem with the videos, when I go through each video the camera takes that day. I click on manage events and proceed to check off the videos I viewed and don't need to save. Problem is that the video does not delete and if it does it's a delayed reaction, it deletes only two at a time or not at all. Not sure what to do about this ongoing problem, anyone experience this?
To be clear, you're not only selecting videos but also the trashcan icon, right? Have you rebooted the phone and reinstalled the app as well as trying a different device? What happens if you use the web client (my.arlo.com) to do this?
Yes, I am selecting the videos and using the trash can icon. They are not deleting or very slow to delete, at times I can only delete two at a time. I will have my son reinstall the app, thank you. I'll see if that works, which I hope it does.
Are you still seeing this same behavior?
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
