2 way audio arlo pro 5s
Is it natural or something wrong with my arlo.the issue is. The 2 way audio I can hear them through the camera good but they can't hear me when I talk to them through the cam or is there a setting g I need to change . I have three cam I check all their setting the audio is all ready at max
Check the phone settings for the app and verify the mic permission is enabled.
Yeah I check that and everything is good it just that it's so low that they can't hear me I test with different device it's still low and devi e is up to date
Check the speaker settings for the camera.
This can be found under Settings > Locations and Plans > Devices > select your Pro 5 > Audio Settings > Make sure the slider is set to 100%
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
