  • 12 Replies
  • 2863 Views
highpockets003
In the software, under FEED (on an iPad), i can watch a stored event. Without having to delete that event, HOW DO I get back to the FEED ARCHIVE? There are no arrows or buttons to take me backwards into the feed archive.
12 REPLIES 12
On my iPhone there is a < in the upper left corner.  When I press that, I return to the Feed.
highpockets003
well, there ain't that arrow anywhere on the screen of the ipad. how do i go back?
highpockets003
and there ain't no < on the video events screen on an Android either.
FWIW, I see it on my ipad.
highpockets003
Weeeelllllll - do you have an answer for this software problem?
No idea why you aren't seeing it.  I'm tagging the mods ( @JamesC and @ShayneS ) , hopefully they will add it to the list of things to investigate/fix.
Just saw a work-around from another user.  Try rotating the screen by 180 degrees, and see if the arrow appears.
highpockets003
180° does not work.
But - rotating the screen 90° does reveal an arrow in the top left corner. How do I fix the problem though to view the videos on normal orientation?
I'm not able to replicate this issue on iOS (using an iPad) or on Android.
What mode iPad are you using?
highpockets003
iOS 16.3.1
iPad Pro 2nd gen, MXDC2LL/A
highpockets003
well, guess you guys can't fix your own software problem.
you need an 800 number for purchasers to call.
highpockets003,
I'm working with the team internally to better understand why you may be experiencing this behavior.
Additionally, you can contact Arlo Support using the Arlo mobile app under Settings > Support Center
  • 12 Replies
  • 2864 Views
