Hi i have a pro 4 and im have problems setting the recording time ,and how do i update my app .im 71so thet should explain alot ,Thanks
If you select the mode in the app, you'll then see a rule for the camera. Edit the rule, and there is a setting for the recording time there.
Here's a screen shot of the relevant screen (using the web interface of my.arlo.com, though it is also available in the app):
When you are done, be care to save it. In the app there will be a save control at the top right of the screen. In the web ui, you click on back, and then scroll down to the bottom of the screen. There is a cancel and save control there.
Arlo Pro 4
labels
Samsung SmartThings
