arlo pro 4
  • 1 Reply
  • 786 Views
scotch08
why does my pro 4 cameras record every minute for 10 seconds when there is no motion
Is this literally every minute?  Or just a lot?
Do you have audio detection enabled?
Maybe first try putting a camera into a closet (or perhaps a closed box), and see if that continues.
The motion detection uses a passive infrared (PIR) sensor, and there are some locations when heat (including thermals in the wind) will set it off, even though there is no apparent motion.  You can change motion detection settings to control this, but I think it would be good to confirm that the cameras are working properly first.
  • 1 Reply
  • 787 Views
