Wifi
  • 2 Replies
  • 1233 Views
Lauren33
If my wi if isn’t 2g is there options to buy at Arlo be able to have my cameras to connect with phone?
One option is to get the new Pro-5 camera, which can connect to 5 gHz wifi.
To clarify: if you purchase a camera that is 2.4 gHz only (for instance an Essential or a Pro 4), then the camera needs 2.4 gHz to connect to the Arlo cloud - not just for onboarding with your phone.  You can purchase an WiFi extender to create a 2.4 gHz network if your router doesn't have that - though Arlo doesn't see them.  Note that almost all 5 ghz routers are actually dual band, so you probably don't need to purchase anything.
Lauren33
I do have the pro 4. The problem is my 2g doesn’t show up unless I literally go outside down my driveway. I will go to a Best Buy today and ask about the extender.  That’s a good idea
  • 2 Replies
  • 1234 Views
