Why is Arlo app draining my battery!!??
  • 17 Replies
  • 417 Views
  • 5 In Conversation
029kid
Arlo uses 55% battery, it kills my phone.
What is wrong?
17 REPLIES 17
BrookeN
Are oyu on Android or iOS?
I've found that somehow going to Feed may or may not cause the CPU usage to jump up to 50%, draining the battery. Force closing the  app and reopening it solves the issue until it happens again. I now use a CPU monitor to see if the CPU settles down after leaving the app or not so I can react quickly.
029kid
Why was my post just deleted ?
Im on Android, Google Pixel 8 Pro, latest fw and also latest Arlo app sw.
This battery drain must be fixed, Arlo app kills my phone and I have to uninstall unless it gets fixed. As the phone now works as a car key its pretty bad that the Arlo app behaves like this
Edinburgh_lad1
Hero
Hero
Wow, what happens to your car when you lose your phone?
@029kid did you try force closing the app and then reopening as I suggested above?
029kid
Well, I use the phone to lock and unlock my Tesla. The other day I had to walk home as the phone drained 20% > 0% in no time.
029kid
Yes, that will work. But it's not a permanent fix.
BrookeN
We are aware of the behavior you are seeing and it is currently being investigated. I will update the community as soon as possible.
029kid
BrookeN
@029kid can you please update to 6.5.1?
029kid
6.4.5_6040502 is the latest? No newer @ Play Store.
BrookeN
Can you check if you see the update as of now?
FWIW, I check multiple times a day and still no update to 6.5.x - stuck on 6.4.6.
029kid
Still no new update for me as well.
BrookeN
It is on a rollout right now, it is at about 10% as of today.
alex_loo
Virtuoso
Virtuoso
I had something similar (40-ish %) recently (android app 6.5.0, phone was so hot!) but after updating to android app 6.5.2, the app is now only taking 4% battery, which sounds normal.
Hopefully this is not turning bad again.
Alex
BrookeN
A fix is on the way. I will update you as soon as it is rolled out.
  • 17 Replies
  • 418 Views
  • 5 In Conversation
