What is the reference of the external power cable for Arlo Pro4 with a European plug
What is the reference of the external power cable for Arlo Pro4 with a European plug: VMA5600C? On arlo.com, the only external cable offered for Arlo Pro 4 has the reference VMA5601C-100PES and the photo shows a UK/HK plug.
Hi @JeromeT
It looks like any Arlo external power cable that is compatible with Ultra, Pro 5, Wire free Floodlight, Go v2 should be compatible with the Pro 4.
Thank you for your reply. My question is : which reference should I order to make sure it goes into a European socket ? On Arlo's French website, the models on display only feature uk plugs... Sorry for being not clear enough... Bedt regards, Jérôme
Arlo Pro 4
labels
Samsung SmartThings
