What is the reference of the external power cable for Arlo Pro4 with a European plug
  • 4 Replies
  • 1000 Views
JeromeT
What is the reference of the external power cable for Arlo Pro4 with a European plug: VMA5600C? On arlo.com, the only external cable offered for Arlo Pro 4 has the reference VMA5601C-100PES and the photo shows a UK/HK plug.
Best answers
  • ShayneS
    @JeromeT
    If you place an order from your region, it should be the correct plug.
You do want either the VMA5600C-PES (white) or the  VMA5601C-PES (Black).
I think the kit supports both Europlug and UK. I'm tagging the mods - @BrookeN , @JamesC , @ShayneS - so hopefully one of them will confirm.
ShayneS
Hi @JeromeT
It looks like any Arlo external power cable that is compatible with Ultra, Pro 5, Wire free Floodlight, Go v2 should be compatible with the Pro 4.
JeromeT
Thank you for your reply.  My question is : which reference should I order to make sure it goes into a European socket ? On Arlo's French website, the models on display only feature uk plugs... Sorry for being not clear enough... Bedt regards, Jérôme
ShayneS
@JeromeT
  • 4 Replies
  • 1001 Views
