Video Library Filters
The Arlo app doesn't show all the videos by default in the library. I have to go in the Filter and select the cameras and then the videos will show up. However, the filter resets itself if I delete the videos from the library for a camera. I then again have to go in and select the cameras in the filter if a new clip is recorded. Is there a setting elsewhere that just shows all the videos in the library any time there is a recording without me having to select the camera in filter every time?
Select "Device at the top of filter settings and then "deselect all" and when you back out it will say "any". to the right of device. All cams recordings show up and I never had to reset it.
Arlo Pro 4
labels
Samsung SmartThings
