  • 9 Replies
  • 1120 Views
RLF7777
All camera working, deleted photos not needed, no pictures for 12 hours.
9 REPLIES 9
Have you tested motion detection by walking in front of the camera? If connected to a router, have you rebooted the router and camera? If connected to a base or hub, have you rebooted that base/hub? Removing and reinserting the battery may help, too.
Of course, ensure that your mode is set properly and not to Disarmed.
RLF7777
The cameras are at a vacation home 2 hours away.  Yesterday when we looked at cameras they were working. I deleted photos that were not needed and now no pictures since 3:00pm yesterday. Would deleting photos have caused this.
RLF7777
The cameras are showing live feed.
No, deleting videos wouldn't do this. Can you use live view and manually record? Have you checked your active mode?
RLF7777
Yes, I just took picture
RLF7777
I can see live and can record. How do find active mode.
Can you live stream the camera(s)?  If so, can you save a manual video recording or snapshot?
Note if you have 2K livestreaming enabled, you will need to disable it to try this test.
Can you live stream the cameras? If so, can you make a manual recording?
Use the Mode selection at the bottom or the app. Depending on how the camera is connected, you should see either the camera(s) or a hub. Click on the camera to see the active mode or click on the hub and then check what mode is selected.
  • 9 Replies
  • 1121 Views
