Unit won’t focus
I just changed the battery to one Arlo 4 and now the picture is blurry.
I tried a reset and remove and re-add it.
im not able to zoom in or out.
if I aim the unit to a window it shows light, but unable to focus.
Arlo cameras don't focus - they're fixed focus. It's possible that you smeared something on the lens or pushed on the lens causing it to be displaced.
Here is what I see through the camera.
Trying to adjust the view through my iPhone doesn't change the view.
I didn't touch the lens when I changed the battery.
@FLLarry wrote:Trying to adjust the view through my iPhone doesn't change the view.
Did you try to zoom out the picture? It looks like it might be fully zoomed in.
@FLLarry wrote:
Zooming in or out doesn't make any difference.If I aim the camera towards a window, I can see a blur of light, but not able to adjust it to focus.
You could try a hardware reset:
- remove the camera from the account
- open the housing and press the sync button inside until the LED flashes amber (about 15 sec)
- add the camera back to your account
Arlo Pro 4
labels
Samsung SmartThings
