Tool to open and remove battery from camera is GONE! How do I get a new one?
Tool to open and remove battery from camera is GONE! How do I get a new one? Not from point of purchase that is for sure. Best Buy simply knows nothing!
Additionally...too many restrictions on how to label inquiry...LABELS will not allow: Battery, Key, Tool, Purchase and these are the words for the why I am inquiring.
There is no tool needed for the normal Pro 4. Are you talking about a camera that uses the security mount?
If so, you can purchase a short 2 mm hex key at a local hardware store.
Arlo Pro 4
labels
Samsung SmartThings
