If I use a smarthub or base will I be able to use my Pro 4 cameras on a 5Ghz wifi connection?
If you use a smarthub, then the camera will connect to the smarthub's wifi.
The Pro 4 only has a 2.4 Ghz radio, so it is not capable of connecting to a 5 Ghz network.
Arlo Pro 4
labels
Samsung SmartThings
