  • 1 Reply
  • 861 Views
HoustonLock
If I use a smarthub or base will I be able to use my Pro 4 cameras on a 5Ghz wifi connection?
If you use a smarthub, then the camera will connect to the smarthub's wifi.
The Pro 4 only has a 2.4 Ghz radio, so it is not capable of connecting to a 5 Ghz network.
  • 1 Reply
  • 862 Views
