  • 1 Reply
  • 1073 Views
ovalit
Arlo Pro 4 connected Smart Hub VMB5000 with 128GB MicroSD card not recording.
Smart Hub Device Info:
Firmware1.17.1.2_1157_0e6c162
HardwareVMB5000r4
Local Storage showing ready, and SD card recording turned ON.
Did you format it in the hub? Have you safely ejected the card and looked at it using a computer to see if any recordings are happening? Is the format FAT32?
  • 1 Reply
  • 1074 Views
