Since it looks like my old Arlo cameras will be worthless pretty soon, I think I'll be upgrading to several Arlo Pro 4 cameras, and I was hoping that someone could answer a few questions:
* ACCESSORIES: Any chance my old magnetic mounts will still work? What about the screw-in wall mounts? The rubber skins? (I get the feeling the Pro 4 doesn't use skins, is that right?)
* NOTIFICATIONS: I've configured the Arlo app to send me an email every time I get a hit from any of my cameras. Will that still work with a Pro 4? (I assume that's a feature of the app, not the camera, right?)
* WEBSITE: I view my Arlo videos via Arlo's website on a PC, not via an app on my phone. Will I still be able to do that?
* HUB: From what I understand, I'll need a hub if I want to do local storage, but other than that I'll no longer need a hub at all. Is that right?
* GOTCHAS: It hardly seems possible, but are there any features that I've gotten used to on my old cameras that I won't get on the new ones? I know I'll have to pay for storage that used to be free, but is there anything else I should know about?
Thank you so much for your help!
Not with the newer Pro4 cameras... as the magnet is now in the base not camera like the older.
Yes, it will work the same....from the app
Yes, the system still works on iOS, Android, and Web
Yes, believe this is correct
There is the required subscription as you know, the new access prgm is different so there will be another learning curve... I haven't seen much difference or loss of options.
A plus is now an easy Home mode.
Arlo Pro 4
labels
Samsung SmartThings
