Purchased 3 Arlo cams, base station, want to store vids on icloud
I’m pretty hacked. I bought 3 cams, trying to record to iCloud. Nope, need to get a base unit to integrate with HomeKit (apple’s home automation solution). Great… Cha-Ching. So I get a hub. Add all the cams to the hub. Yay! Connect to Apple Home kit? Sure. Record to iCloud? NOPE.
I bought the entire system for the ability to record my vids to a storage solution I was already paying for. Why pay for yet another subscription for storage? Arlo said it was compatible. Hmmmmm. It’s not 100% compatible at all. Oh, if I have a USB drive, yippee, but else, no.
My setup is fixin (up to ~ $400 if not more, now) to go back to Amazon. I’m not interested in spending more monthly $$. I’m retired and on a fixed income. Arlo’s statement that they support HomeKit, is not true or valid to the extent of HomeKit’s ability. That needs to be defined or it is FALSE ADVERTISING.
Canalzone6,
Arlo's HomeKit integration does not support storage on iCloud or any other Apple storage feature.
You can read more about the Arlo HomeKit integration (and other partners) here: https://kb.arlo.com/000062278/What-smart-home-and-voice-assistant-systems-can-I-use-with-my-Arlo-dev...
Arlo Pro 4
labels
Samsung SmartThings
