Arlo Pro 4 and Arlo Security Lights
I have 2 Arlo Pro 4 cameras which are connected to my wifi - works great - and now I would like to add a Arlo Security Light.
If I buy the Arlo Security Light with the Arlo Bridge would it then be possible for me to connect the cameras and the light.
Notice: I do not have Arlo Smart Hub for my cameras.
The cameras are already connected, so I don't understand that part of your question.
The bridge connects the security light (which uses Bluetooth BLE) to your home wifi, which then connects to your Arlo account (not a base). So you should be able to add it w/o getting a base/smarthub. It's an old product, so it might not support WPA3.
Arlo Pro 4
labels
Samsung SmartThings
