Pro series with rechargeable batteries. Can this system be hard wired as well.
I have the Pro series with rechargeable batteries. Can this system be hard wired as well. The batteries don't last too long .
You can connect it to the charger 24x7. If the cameras are outdoors, make sure you use a charger that is rated for outdoor use.
Arlo Pro 4
labels
Samsung SmartThings
