Pro 4 with VMA1000B mount
  • 1635 Views
lightfish
I want to buy 3 Pro 4 to be used outside but the mounts (VMA4000B-10000S) is no avalible on Arlo shop.. Can I use the VMA1000B with  the PRO 4 it only says pro and pro 2 in the webshop.
Thanks 🙂
The screw thread is standard, so it should work.
If you are purchasing new mounts, then you have plenty of other options (both from Arlo and third-party).
No. Have you checked retailers like Amazon to see if anyone has stock?
lightfish
bought it and you are right it works
  • 1636 Views
