  • 10 Replies
  • 7025 Views
labsrock
The device stopped recording today. I get the notifications but there is no recording when I go in the app. Have the app installed on my iPhone and iPad and neither show a recording.
labsrock,
Try removing and resyncing the camera. Do you still experience the same behavior?
10 REPLIES 10
dcfox1
Did your 3 month trial of smart run out. You need to subscribe if it did for cloud recordings.
Also if you are connected to a Base or Smart Hub rather then your wifi do you have recordings there if you set up local recording.
labsrock
Subscription doesn’t end until February.  The camera is connected to my WiFi as I don’t have a base or Smart Hub.
labsrock,
If you live stream and manually record, do the clips show up in your library? Do you have a filter set within the library?
labsrock
That is the issue nothing is showing up in my library. I get a notification that there is movement and since I set up the device it always recorded the movement and placed the recording in my library. Now I get the notification but there is nothing in my library.
labsrock
Re-read your message and manually recorded while live streaming. That did work, but it doesn’t work automatically when there’s movement as it did in the past.
labsrock,
What mode are you using? Try creating a new custom mode to see if you experience the same behavior when it is active.
labsrock
I am using Armed mode. Will create a mode and see what happens.
labsrock
Same issue when I create a manual mode. Detects the motion but no recording.
labsrock,
labsrock
That did the trick
  • 10 Replies
  • 7026 Views
