I connected my three Pro 4 cameras to my base station to record motion locally but could only arm and disarm all 3 cameras together. I tried creating a new arming rule to record two of my three cameras but it seems I can only create a rule for one camera, not two. Is it possible to create a rule to have two cameras armed at the same time?
Assuming you're using the old user interface (UI) that uses Library to view videos, once you've created a mode that has that one camera rule, just re-edit the mode to add more cameras.
It worked, thank you!
Arlo Pro 4
labels
Samsung SmartThings
